I’m getting a strange error when trying to do a plain ujust update. Out of the blue, it cannot upgrade the NVIDIA packages in distrobox.
I’ve rebased, reset rpm-ostree, tried fiddling with distrobox to clear the caches, nothing.
Any idea? Here’s the log section for the failing distrobox upgrade:
ujust update
── 23:30:42 - System update ────────────────────────────────────────────────────
==== AUTHENTICATING FOR org.projectatomic.rpmostree1.upgrade ====
Authentication is required to update software
Authenticating as: me
Password:
==== AUTHENTICATION COMPLETE ====
Pulling manifest: ostree-unverified-registry:ghcr.io/ublue-os/bazzite-gnome-nvidia:stable
No upgrade available.
── 23:30:46 - Distrobox ────────────────────────────────────────────────────────
Upgrading fedora...
distrobox: Installing basic packages...
/usr/bin/dnf
Last metadata expiration check: 0:44:00 ago on Sat 01 Jun 2024 10:46:47 PM WEST.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
audit-libs x86_64 3.1.3-1.fc39 updates 124 k
cups-libs x86_64 1:2.4.8-3.fc39 updates 267 k
git x86_64 2.45.1-1.fc39 updates 53 k
git-core x86_64 2.45.1-1.fc39 updates 4.7 M
git-core-doc noarch 2.45.1-1.fc39 updates 2.9 M
glibmm2.4 x86_64 2.66.7-1.fc39 updates 680 k
hwdata noarch 0.382-1.fc39 updates 1.6 M
libaom x86_64 3.9.0-1.fc39 updates 1.8 M
libgcc x86_64 13.3.1-1.fc39 updates 118 k
libgomp x86_64 13.3.1-1.fc39 updates 328 k
libsolv x86_64 0.7.29-1.fc39 updates 426 k
libstdc++ x86_64 13.3.1-1.fc39 updates 869 k
libusb1 x86_64 1.0.27-2.fc39 updates 76 k
libva-nvidia-driver x86_64 0.0.12-1.fc39 updates 51 k
zsh x86_64 5.9-10.fc39 updates 3.3 M
Transaction Summary
Upgrade 34 Packages
Total size: 31 M
Downloading Packages:
[SKIPPED] openh264-2.4.1-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] audit-libs-3.1.3-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] cups-libs-2.4.8-3.fc39.x86_64.rpm: Already downloaded
[SKIPPED] git-2.45.1-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] git-core-2.45.1-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] git-core-doc-2.45.1-1.fc39.noarch.rpm: Already downloaded
[SKIPPED] glibmm2.4-2.66.7-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] hwdata-0.382-1.fc39.noarch.rpm: Already downloaded
[SKIPPED] libaom-3.9.0-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] libgcc-13.3.1-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] libgomp-13.3.1-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] libsolv-0.7.29-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] libstdc++-13.3.1-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] libusb1-1.0.27-2.fc39.x86_64.rpm: Already downloaded
[SKIPPED] libva-nvidia-driver-0.0.12-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] nano-7.2-5.fc39.x86_64.rpm: Already downloaded
[SKIPPED] nano-default-editor-7.2-5.fc39.noarch.rpm: Already downloaded
[SKIPPED] osinfo-db-20240510-1.fc39.noarch.rpm: Already downloaded
[SKIPPED] perl-Git-2.45.1-1.fc39.noarch.rpm: Already downloaded
[SKIPPED] pipewire-1.0.7-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] pipewire-alsa-1.0.7-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] pipewire-libs-1.0.7-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] pipewire-pulseaudio-1.0.7-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] python3-unbound-1.20.0-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-boot-unsigned-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-libs-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-networkd-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-pam-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-resolved-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] systemd-udev-254.13-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] unbound-anchor-1.20.0-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] unbound-libs-1.20.0-1.fc39.x86_64.rpm: Already downloaded
[SKIPPED] zsh-5.9-10.fc39.x86_64.rpm: Already downloaded
Running transaction check
Transaction check succeeded.
Running transaction test
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: Transaction test error:
installing package libva-nvidia-driver-0.0.12-1.fc39.x86_64 needs 16KB more space on the /usr/share/doc/libva-nvidia-driver filesystem
Error Summary
Disk Requirements:
At least 1MB more space needed on the /usr/share/doc/libva-nvidia-driver filesystem.
Error: An error occurred
