Updates aren't working
Hi all,
I’m using the HTPC version of Bazzite on my desktop.
For a while now, I haven’t been able to update the system through ujust update.
And Steam updates don’t work. I’m aware of the issue in July that prevented updates, but I’ve tried the fix for that, and it still doesn’t work.
ujust update gives me this error:
error: Checkout chkconfig-1.27-1.fc40.x86_64: Hardlinking fc/fd9a74cdb18fbebd7e904eb6887ddecb69045d96903782dc4879d4223e82ec.file to init.d: File exists
System update failed:
0: Command failed: /usr/bin/rpm-ostree upgrade
1: /usr/bin/rpm-ostree failed: exit status: 1
Running ostree fsck gives this error:
bazzite@bazzite:~$ sudo ostree fsck
[sudo] bazzite のパスワード:
Validating refs…
Validating refs in collections…
Enumerating commits…
Verifying content integrity of 402 commit objects…
fsck objects (407/246029) [ ] 0%
error: In commits 9dde7aeb83d0d6e4dc9c8cc5f4f7b29e072fe63148ffc9b7c8be72e2416da619, c66aaa47c1ada77cd585effda712fe58499150c7966e2479969e3244365f0cb5, 24b87af632a000222b3f19c999dc78d362db35c2d20245a138f5fda74a41da2e, 7f869df0c32aff91b659d98f0fbe7ab85dda83a7c3578d63cb6cf61a8c2e9cc8: fsck content object 5b833668330c86f378699ed02cb5874c11dac8c39a30e230ccca47539803c6f2: Corrupted file object; checksum expected=‘5b833668330c86f378699ed02cb5874c11dac8c39a30e230ccca47539803c6f2’ actual=‘bf13d8fe63612425b89f526a906f06359a1a71ac71902caef8a7160558d91187’
I tried rollback a while ago, and I thought it was fixed, but I guess not, it’s still the same. Does anyone have any suggestions for how to fix this?
Thanks in advance.
Maybe try:
rpm-ostree update
If that doesn’t do it you could rpm-ostree reset and then try update again. Just be mindful that reset will do away with any layered packages and you’ll have to add them back.
Edit:
Also ujust clean-system will delete any cached data and pull in new, incase maybe something cached was somehow corrupted.
Running ostree reset seems to have fixed it. I was able to run ujust update without errors. I just have to reinstall a couple of things, but that’s fine.
Thanks a lot for your help.
