When manually executing ujust update from terminal in Blufin-stable, Quit used to exit terminal ans Shell was option to stay in terminal. Now it looks both have the same result. Is this intentional?
When you use the update ‘programme’ from the ‘system upgrade’ then it quits completely when you quit. When you choose ‘shell’ it will give you a shell. That’s all.
