Trouble with Bazaar
Since the previous flatpak-store (I already forgot it’s name, what a terrible memory I have!) disappeared and is replaced by Bazaar, I encounter trouble downloading new applications and updating existing ones. Also removing applications is sometimes a problem.
The trouble is always Bazaar seems to do what I ask, but gets stuck.
What can I check?
This is what happens when using the update button: https://sync.han-pilate.be/s/5ETFfAPZzJFb5mK
That looks like a really really old version of Bazaar.
Depending what you are running (bazzite, aurora, bluefin) update your image or flatpaks
I found the problem!
I had to give Bazaar more permissions with Flatseal, to access all files.
I don’t know, it’s just for a few weeks that Bazaar appeared on my system replacing the previous application that handled installations (was it called “Software” I don’t know). I try to restart my computer at least once in two days, so I guess it should be up to date?
Still didn’t get what are you using.
rpm-ostree status
Also please provide info about Bazaar flatpak:
flatpak info io.github.kolunmi.Bazaar
Try to manually update both system and flatpak with:
ujust update
I have to admit that I don’t understand why you have to give Bazaar more permissions to access all files. Which permissions did you add?
My understanding is that basically Bazaar needs access to /var/lib/flatpak and if I look here at my Aurora system I see that Bazaar has
which looks ok to me.
Well, appearantly it needed more permissions, because it wouldn’t update, delete or add applications and now I added a few permissions, it does.
Probably I activated too many, but it works, so I leave it like this.
The result is this:
Bazaar - Ontdek en installeer applicaties
          Ref: app/io.github.kolunmi.Bazaar/x86_64/stable
         Arch: x86_64
       Branch: stable
       Versie: 0.6.2
     Licentie: GPL-3.0-or-later
     Herkomst: flathub
  Verzameling: org.flathub.Stable
  Installatie: system
Geïnstalleerd: 15,5 MB
      Runtime: org.gnome.Platform/x86_64/49
          SDK: org.gnome.Sdk/x86_64/49
       Commit: fbebf74492067ac5f6fa0f544b8e358a77105651adb565bd27fc8b48be0d36b2
 Bovenliggend: f1d593d2229867a53b7a2b0785a716322ff254b1b4ca8c981363bb7e6888be26
    Onderwerp: Merge pull request #68 from kolunmi/0.6.2 (935d2900fc97)
        Datum: 2025-12-10 03:29:00 +0000
But I saw Bazaar itself was also updated once I allowed it more permissions, so this is after the problem began.
❯ rpm-ostree status
State: idle
AutomaticUpdates: stage; rpm-ostreed-automatic.timer: inactive
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx:gts
                   Digest: sha256:1f054a4f768f804fcd809b51effb485f71fa46271ada573053aac275af147698
                  Version: gts-42.20251209.1 (2025-12-09T03:26:41Z)
          LayeredPackages: midisport-firmware
                   Digest: sha256:c342b65e06bfc899760e337d6866b9a464d26ee66f55c09e00453713fef452ed
                  Version: gts-42.20251204 (2025-12-04T12:29:41Z)
Hm, strange. Bazaar is working ok for me without granting any additional permissions.
Dont know why you would need to enable those
Mine from stock installation (aurora)
