Stop Bazaar from running in the background
Hi,
The new bazaar app store is great, and I like it much better than Discover, which was so bad.
But every now and then I’ll catch bazaar running in the background using a lot of CPU. Just a few minutes ago, I opened up System Monitor and spotted a “bazaar-hotfix” process at the top of the list using 11% CPU, even tough I never opened it.
I assume it’s just checking for updates or something like that, but I can’t seem to find a way to disable it. I do not want automatic updates, nor do I want it to run unless I launch it. Is there a way to do that?
Thanks!
There was a bug in Bazaar that was fixed in a new version. Should probably ship with next system update, for now just kill a background process.
Just had a new system update which updated Bazaar as well but the issue still persists. Bazaar and bazaardlworker processes still remain running in the background.
That is normal, the bug was the CPU usage when the parent process is killed.
Seeing as the question was never actually answered and I agree with OP about not wanting Bazaar in the background always running here is the fix:
There is a global systemd service, that runs in the user context, which launches the the bazaar background service on login. Disable this by running the following:
sudo systemctl --global disable bazaar.service
systemctl --user disable --now bazaar.service
Next we need to handle Bazaar sticking around after closing the window. You can handle this in Gnome Settings:
Then if you don’t want your system doing auto updates you need to disable that service as well using:
ujust toggle-updates
That seems to miss some brew timers so you can handle that with:
sudo systemctl disable --now brew-update.timer
sudo systemctl disable --now brew-upgrade.timer
Also seems to miss flatpak so handle that with:
sudo systemctl --global disable flatpak-user-update.timer
systemctl --user disable --now flatpak-user-update.timer
You can review any additional systemd based timers with:
sudo systemctl list-timers
systemctl --user list-timers
It looks like cron isn’t installed in bluefin by default so no need to review all of those potential timer locations but feel free to double check that on your system.
Lastly whenever you want to update you can just run ujust update on whatever schedule you desire. This seems to handle the OS, Flatpak, and Brew.
Hope this helps!
If anyone is wondering why Bazaar runs in the background in the first place: It’s apparently necessary for the Bazaar search results in GNOME shell (Bazaar implements the org.gnome.Shell.SearchProvider2 D-Bus interface).
So, following the previous post’s steps to disable Bazaar running in the background has the side effect of no longer offering uninstalled Flatpak apps as a search result category in GNOME Shell.
So we dont need Bazaar running in the background to keep the Flatpaks updated?
I thought it was either that or a bug..
No, you don’t.
System flatpaks are updated by uupd.service every 6 hours.
User flatpaks (there are none installed by default) are updated by flatpak-user-update.service once a day.
# to list active timers
Just a quick information. If you want to properly close Bazaar, click the hamburger menu icon and click “Quit Bazaar” or its keyboard equivalent “Ctrl+Q.” This makes Bazaar close fully. You can check system monitor and see for yourself.
Any other way and it keeps running in the background :slight_smile:
`uupd` also updates user flatpaks
So why does Bazaar run in the background by design when you close the window? What’s the purpose of that?
One thing I can think of is so that you don’t accidentally abort a download or installation by clicking the ‘X’ icon by mistake. Or maybe it has to periodically update repositories etc. I’m not a maintainer so I wouldn’t know, but at the very least it will run quicker. Each time you cold-start Bazaar it checks repositories etc. which takes a few seconds for example.
For a regular user, this would make no noticeable impact and I probably would’ve made the same choice if it was up to me. But at the same time I know it’s annoying to users who are sensitive to this type of stuff (like me).
It’s a compromise I guess.
This applies to every app: keep it running in the background and it will start faster. That cannot be a justification to keep this app running. It would give every app developer justificiation to always keep their apps running..
If anything it should be closing by default and if processes are still running, just show a popup that its currently installing/uninstalling, can’t close now.
Yes please can we get Bazaar to close fully when the app is closed. If it doesn’t need to run in the background it shouldn’t. Or should be a toggle in it’s settings.
No, as its needed for search results to work in KDE/Gnome.
Also this is not the right place to put requests in. Those should go to GitHub · Where software is built
Why it’s in the background has been answered and this thread has run it’s course. Closing it.
