Ever since November I can’t launch Bazaar anymore. My current version is:
I suspect this is because of the change over to flatpak but I’m not sure.
Let me know if there are other diagnostics I should share, I’m a little new to troubleshooting this sort of thing
inffy
December 4, 2025, 5:20am
2
how are you trying to launch it?
does it launch from terminal with flatpak run io.github.kolunmi.Bazaar
Oh! That works! How strange!
I was launching through KRunner or else the application dashboard.
Also I noticed: In KRunner I only get the usual “Install with Bazaar” recommendations when I have bazaar open using the method you suggested for launching it. After I close the window I don’t get “Install with Bazaar” recommendations anymore
Could it be that you have a local, i.e. in ~/.local/share/applications/ Bazaar desktop file which points to an earlier RPM-installed Bazaar ?
There is indeed!
It’s called io.github.kolunmi.Bazaar.desktop
Should I simply delete this?
Its content is:
[Desktop Entry]
Categories=Utility;
Comment=Add, remove or update flatpak software on this computer
Exec=bazaar window --auto-service %U
Icon=openbazaar2client
Keywords=GTK;System;PackageManager;Discover;Flatpak;Software;Store;
MimeType=x-scheme-handler/appstream;x-scheme-handler/flatpak;x-scheme-handler/flatpak+https;
Name=Bazaar
NoDisplay=false
Path=
PrefersNonDefaultGPU=false
StartupNotify=true
Terminal=false
TerminalOptions=
Type=Application
X-KDE-SubstituteUID=false
X-KDE-Username=
inffy
December 5, 2025, 11:11pm
6
That is the old rpm version.
Ok! So all it took to fix the error was that I had to delete the file
~/.local/share/applications/io.github.kolunmi.Bazaar.desktop
Thanks for everyone’s help!
