Thunderbird Crashes
Running bazzite-nvidia-kde; current version. Thunderbird (flatpak) crashes very frequently; I am barely able to send an email. Anyone else experiencing this? Already tried flatpak repair and thought that fixed the issue but it didn’t. Crash report here: thunderbird crash - Pastebin.com
Any advice?
Start Thunderbird from terminal:
flatpak run org.mozilla.Thunderbird
and see if some error is dispayed when crash appears and then search web for error message.
Hey,
You can try Betterbird, a fine-tuned version of Mozilla Thunderbird available in Flathub, and see if it makes any difference.
Thanks, I actually already tried that but everytime I launch TB from the console it doesnt crash… But I will continue to monitor it that way.
Thanks for the suggestion. I will give it a try.
My crashes went away after clearing the cache.
Thanks for the suggestion, didn’t solve the problem for me. Using Betterbird now, which doesn’t crash.
