Rebase from Silverblue to Bluefin
Hello there!
I have been happily using silverblue-nvidia images for a while now and decided to give bluefin-nvida a try.
Rebasing worked fine, however, the default Flatpaks didn’t get installed (easy enough to fix) which made me wonder whether there was any other setup that would differentiate my current system from a clean Bluefin installation? If so, how would I change that (ideally without having to do a clean install myself)?
Same for the reverse, if I decided to go back to Silverblue, would a simple rebase do the trick or is there anything else to set up or reverse?
ujust install-system-flatpaks will catch up your flatpaks.
other differences we can’t account for, but you’ll probably be fine.
Thanks for letting me know!
For the record, what would those other differences be? Based on that I could see whether it’s worth it for me to get a clean install at some point down the road.
Not sure, I don’t think anyone’s gone through and checked off every item on the differences.
EDIT: Though you’re probably fine.
All right then, I’ll keep it as it is. If something appears very broken I’ll let yall know.
