Help Rebasing to Bluefin from Silverblue
Hello,
I would like to migrate from silverblue to bluefin-dx. I actually have some packages installed with rpm-ostree and some flatpaks packages.
What is the best way to migrate to bluefin-dx ?
Should I install it from scratch ?
Should I “rebase” my system ? If yes, do I need to remove my rpm-ostree packages ? Can I keep my flatpaks ?
Thanks for your advice :slight_smile:
A big thanks for this answer, very clear and detailed !
So I will soon follow your advice: install bluefin from scratch :slight_smile:
looking forward to joining this community !
