Msi claw a8 sleep
Hello everyone, I have recently acquired this machine and after updating drivers, bios etc. I have decided to install bazzite, one of the problems to take into account is that the sleep mode of the machine does not work, when you press it afterwards it does not return from that hibernation you have to hold down the button to turn it off completely and turn it back on I would like to leave a record of them, I have also tried bazzite beta but the problem persists, there are also a couple of things like some decky loaded plugins like boost volume since I consider that the speaker is quite low considering how good they are and how they sound in Windows, and they vibrate the deck to saturate the colors a little more, I suppose this will be more of a decky loaded thing maybe I don’t know…, if you asked to solve the sleep mode problem I would be very grateful since everything else is working quite well. Thanks in advance
I see that the sleep mode has been fixed but there is still one small thing left, the controls disconnect once you return from sleep mode, only the upper buttons work but not the directional buttons and x-a-b-y are lost so you can’t do anything or turn off the machine, is there anything that can be done? Thanks
same here, how did you fixed sleep mode issue?
Same here for my Claw A8. Updated to latest Controller Firmware 3.11 and BIOS E1T8KAMS.103 before installing Bazzite on my device. Now after the device resumes from sleep, controller do not work (except for the 2 extra button up front) and touchscreen also. Would love to provide any logging info for debugging.
