I tried a advanced custom install using an LVM for the root partition and btrfs as its partition type. I created the required EFI(/boot/efi,efi partition type) and boot(/boot,ext4 partition type) partitions but as soon as I click done It stops. I am installing on a UEFI KVM on top of Fedora.
I would like LVM’s so I can increase the size by adding new disks. and expanding to them as I do at work. LVM’s make this so seemless and easy I would recommend them to everyone but it seems this is difficult in bazzite. I wanted to give Bazzite a try because it sounds exactly what I want as a gaming distro.
I have shared via pci pass through the amd/ati video card and related audio and a usb bus that I plugged a USB hub into.
