I have tried it for 4 times now to install bazzite and it still won’t show up as a bootable option I have tried this both live iso and normal iso and each one will not make it show up. Every Linux distro I have created on usb always showed up but for some reason bazzite won’t show up. I verified the checksums.
I have tried GPT option in the 4th attempt and Rufus tells me when its partitioning GPT it says “This operation returned because the timeout period expired”
This should not be happening because I have a LENOVO LEGION Laptop 83DG with GEFORCE RTX 4060. I am using dual boot with Windows and Linux. The Linux partition is 50gb. Bazzite is designed for gaming so why is it not working for me?
Here is what I chose:
What hardware are you using?
Other Laptop
Who is the vendor of your primary GPU?
Nvidia (RTX Series | GTX 16xx Series+)
What desktop environment do you prefer?
KDE (Like SteamOS’s Desktop)
Do you want Steam Gaming Mode?
No, I want a traditional desktop experience
If you need any more information about my drivers tell me and i will responed as soon as possible
Update: I have tried again but this time rufus GPT worked but in 31.4% after 30+ minutes of waiting it said error and windows made a notification which said something that usb malfunctioned i have tried diskpart command and i still cant find it how could it break my usb? i will try find a way to fix the usb or try a new usb
