GPD Win Mini stuck on 120Hz
Hi,
I recently installed Bazzite on my GPD Win mini 2024, I noticed that the frame limit slider is stuck on 120Hz for any FPS I set it to.
I have tried disabling frame rate limit and the only refresh rate is still 120Hz. If I try to move the slider, it states that it is an undefined refresh rate. I also tried toggling the external display refresh control option in the developer mode section, it doesn’t seem to do anything whether it is on or off.
I have also tried adding variables to the /etc/environment file. STEAM_DISPLAY_REFRESH_LIMITS and GAMESCOPE_OVERRIDE_REFRESH_RATE, doesn’t seem to have any effect when I try to add custom refresh rates. However, adding “CUSTOM_REFRESH_RATE=40-120” to the environment file did allow 40-120Hz refresh rate to be added. The only issue is that when I choose lower frame limit, such as 40 and 60 FPS, it defaults back to 120Hz instead of 40 and 60Hz.
Is there any work around or fix for this? Hopefully this is the correct location for me to post this.
Thank you
