Hey I’m new to bazzite, but I wanted to give it a try on my rog ally. Everything is going well so far but I did notice that the frame limiter is locked to 120hz when VRR is on. Is that a bug? or can I not limit my fps while it’s on.
This is an issue with gamescope. Just disable VRR when you use the frame limiter.
Sounds good! Thanks for the reply.
