Bluefin installation error
Trying to install bluefin-dx-gts.iso on a framework 16. Wrote the iso to USB with mediawriter. No specific settings on install, everything on auto on unallocated space. Stuck on this error, tried multiple times.
Have a parallel fedora workstation and windows installation.
Any ideas ?
Ok i read online that dualboot is not reliably supported with fedora workstation and silverblue. will try to get rid of workstation now
Fixed by completely removing all existing Fedora partitions, including EFI system partition (it’s not enough to mount that again)
