Install issues Bluefin & Aurora 41
I am unable to install either Bluefin or Aurora 41. When the installation is about to finish, an error occurs stating that it is “unable to write to EFI” or “unable to write to the boot partition,” and it mentions a kernel bug. I experience the same issue with Fedora 41 KDE as well.
I am using an NVIDIA GTX 1650 GPU. The original Aurora 40 works, but the latest image update to 41 along with the latest NVIDIA driver doesn’t activate the second monitor.
am i the only one with this issue? unable to go any further after the bluefin formats the ssd and presented with some nonsensical error?
Bad iso flash or hardware issue (ssd efi not empty etc)
I can install Aurora fine, just downloaded a new -latest ISO and it installed fine.
Thanks for the tips and its great it worked for you. Solus installs fine (gnome and kde) so thanks for the feed back as feedback as such (works for me) is of no help
I got it installed. It had nothing to do with an occupied efi
I disabled all m2 nvme drives in bios and it installed
But the nvidia issue still stands
565.57x dosnt turn on 2nd monitor
565.34x works with no issues
