Bluefin installation failure
The following error occurred during installation.
Tried:
  1. Removing EFI partition as showed here (It was empty)
  2. efibootmng didn’t show any conflicted entry
  3. Wiping the whole disk with dd
Nothing helps. What else can I do? :pensive:
More info:
Previous OS was Fedora Workstation
Laptop is Lenovo IdeaPad 3 15IGL05
Try flashing the iso to the usb again, I don’t know what this issue is, but that might help
this definitely happened to me on my laptop. i gave up for afew days, then worked out of no where.
i ran it from ventoy on a 256gb ssd portable
I did encounter a similar issue a few weeks back, but using fedora media writer usually works better.
NOT A BLUEFIN ISSUE!!!
Fixed by buying a new usb :woozy_face:
