Background:
- Had Bazzite/kde dual booting with Win10 after rebase from Bazzite-Deck which didn’t work.
- Upgrade to Bazzite 41 did not work out and got black screen during Wayland loading… per my other thread.
- Rollback was not available on Grub menu.
- Tried to clean install Bazzite/Gnome over top of Bazzite, but installer crashed part way through with long error code starting with “The command ‘ostree admin instutil set-kargs rhgb quiet root=UUID=79ee3036… etc=rootflags=subval=root00rw’ exited with the code 1.”
- GRUB is now borked and doesn’t list any installations including windows, only gives a command prompt.
- Decided to use Blevit-GUI to delete sda4 where Bazzite resides to create free space for Bazzite installer to set it’s volumes automatically.
- Blivet-GUI shows existing Bazzite volumes and partition are ready for deletion and I click “accept”.
- It seems that clicking Done after accept does not actually make the requested changes. When I go back into the disk selection screen, the automatic selector only shows a tiny amount of free space and all the original Bazzite BTRFS volumes are still there.
Where I am now:
- So I’m left with the only option being manual volume creation. I go through the volume and partition deletion procedure again and am at the screen shown in the attached pic, but I don’t know what volumes need to be set up here for the dual boot to work properly… please help!
Thank you,
S.
edit: added line about Windows not showing in GRUB
