Bazaar not working categories are blank and unable to sync manually
Get this error when opening Bazaar for the first time, I am unable to use the Sync Manually option making the Bazaar marketplace unusable. Any way to resolve this as looking for others with the same issue shows no results, first time installer about an hour ago.
Failed to synchronize appstream data for remote ‘flathub’: While pulling appstream2/x86_64 from remote flathub: While fetching ``https://dl.flathub.org/repo/delta-indexes/yh/y_x3mNH5ogm7GFS2fmgtGynUZEsA_K+PexRgqGhJc.index:`` [28] Timeout was reached
Having this issue as well. Ran ujust update, flatpak repair, etc. and have gotten nowhere. First time Bazzite user.
I took this to discord to get a response:
I did attempt to resolve before this which DID get the Bazaar working which was:
I THINK I have resolved issues my end by using: Terminal → flatpak update -vv → proceeded with changes to system installation. Now I can open the Bazaar and have been able to download, install and open discord as a test.
But as it stands now this is not a Bazzite issue but a flathub issue.
I have the same issues. After some time I got “You have a network connection but are viewing a cached version of Flathub” with the “Sync Manually” button.
I pressed that, and it failed with a timeout - even though, I’m watching youtube and am game streaming - and my connection is perfectly fine:
Failed to synchronize appstream data for remote ‘flathub’: While pulling appstream2/x86_64 from remote flathub: While fetching https://dl.flathub.org/repo/delta-indexes/y_/NVkw8c3ymSHkDCYKpheBOJZL2LR4IYQVtrbq4osLU.index: [28] Timeout was reached
So something is wrong with either flathub or bazaar at the moment..
Looking a bit closer, I get a 301 “moved permanently” and the download actually does not work. An issue on flathub?
As said flathub is having issues and nothing can be done until the connection/issue is fixed
