Flathub isn't working and Bazaar isn't starting
Bazaar isn’t starting on two different machines, one on Aurora and one on Bluefin.
Flathub.org is showing this
What’s happening? Did I miss the memo? :man_shrugging:
Upstream issue with flathub.org web page. Nothing specific to Universal Blue projects. It has to be fixed upstream.
If you just want to access the website, use the link below for now…this is probably just part of periodic maintenance taking place. No worries.
https://flathub.org/en
Thanks. Is this also the reason Bazaar won’t be starting up?
EDIT: I can reach the Flathub page with your link, but if I try and look for a package, I get the same error page.
Yeah, so they are probably having maintenance here and there atm. I was able to open bazaar just now without issue though on Bazzite. Make sure you have the most up to date version of bazaar with a ujust update command in terminal. I know Bluefin and Aurora use the flatpak versions where as Bazzite is a pre- layered package.
I have both Aurora and Bluefin updated. Bazaar is not working, but I can confirm it’s launching on my husband’s Bazzite gaming system.
Works fine here, although its clearly cached stuff as flathub has been done the whole day today.
