Hey there, I dont know where to report this issue to.
I have three installations of aurora dx on different hardware and bazaar doesnt start on any of them. If I click the bazaar icon, it jumps like 10 times next to my cursor, pops up for a sec in the taskbar and then disappears again. I guess I saw it running like three times or so on some machine.
Till now I used discover but now I see it is gone, so I canโt install software any more.
I am really screwed cause I desperately need to install gimp to manipulate a picture for an email
ps.: luckily I had inkscape installed and somehow managed to mangle my image to a useable state
dalto
March 8, 2026, 3:17pm
2
You can install gimp from the terminal by typing flatpak install gimp.
As for determing why bazaar isnโt working, try running it from the terminal to see if any errors show up there.
thanks for the quick reply!
reporting: GIMP is up and running, yeah!
cli say:
โ bazaar command not found
โ flatpak install bazaar
โ io.github.kolunmi.Bazaar/x86_64/stable is already installed
โ flatpak run io.github.kolunmi.Bazaar
โ (process:2): Gtk-WARNING **: 16:23:02.128: Locale not supported by C library.
Using the fallback โCโ locale.
โ Failed to register: Timeout was reached
โ localectl
โ System Locale: LANG=en_GB.UTF-8
โ VC Keymap: at
โ X11 Layout: at
โ X11 Model: pc105
โ localectl list-locales
โ C.UTF-8
[โฆ]
โ en_GB.UTF-8
both are installed
โ nano/.config/plasma-localerc
โ [Formats]
โ LANG=en_GB.UTF-8
โ LC_ADDRESS=de_AT.UTF-8
โ LC_MEASUREMENT=de_AT.UTF-8
โ LC_MONETARY=de_AT.UTF-8
โ LC_NAME=de_AT.UTF-8
โ LC_NUMERIC=de_AT.UTF-8
โ LC_PAPER=de_AT.UTF-8
โ LC_TELEPHONE=de_AT.UTF-8
โ LC_TIME=de_AT.UTF-8
โ [Translations]
โ LANGUAGE=en_GB:de
Iโve opened an issue for bazaar on github:
opened 03:53PM - 08 Mar 26 UTC
### Describe the bug
โ io.github.kolunmi.Bazaar/x86_64โฆ /stable is already installed
โ localectl
โ VC Keymap: at
โ X11 Layout: at
โ X11 Model: pc105
โ [Formats]
โ LANG=en_GB.UTF-8
โ [Translations]
โ LANGUAGE=en_GB:de
โ C.UTF-8
[โฆ]
โ en_GB.UTF-8
[โฆ]
โ de_AT.UTF-8
all three are installed :confused:
<img width="274" height="184" alt="Image" src="https://github.com/user-attachments/assets/d860bba1-6fb6-4557-853f-5137d2d1f147" />
why u not start bazaar??
### OS
Universal Blue, Aurora DX:stable, KDE,
### Version
โ flatpak info io.github.kolunmi.Bazaar
Bazaar - Apps entdecken und installieren
Ref: app/io.github.kolunmi.Bazaar/x86_64/stable
Arch: x86_64
Branch: stable
Version: 0.7.11
License: GPL-3.0-or-later
Origin: flathub
Collection: org.flathub.Stable
Installation: system
Installed: 17,1 MB
Runtime: org.gnome.Platform/x86_64/49
Sdk: org.gnome.Sdk/x86_64/49
Commit: 54970ee1a029dea91a84d9040a2d826a4a457f3d217d82b91182bdc602cbdef1
Parent: 73a4bef94c271e1d1d4000a836ff0a04521921d7e9b51bb64cebd78539687e77
Subject: Merge pull request #106 from kolunmi/0.7.12 (2069ab570b29)
Date: 2026-03-07 23:46:23 +0000
### Configured Flatpak Remotes
โ flatpak remotes
Name Options
flathub system,filtered
### Hardware
Processors: 8 ร Intelยฎ Coreโข i7-3770K CPU @ 3.50GHz
Memory: 32 GB of RAM (31,3 GB usable)
Graphics Processor: GeForce GTX 660 Ti
### Extra information or context
Operating System: Aurora 43
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.22.0
Qt Version: 6.10.1
Kernel Version: 6.17.12-300.fc43.x86_64 (64-bit)
Graphics Platform: Wayland
โ rpm-ostree status
State: idle
AutomaticUpdates: stage; rpm-ostreed-automatic.timer: inactive
Deployments:
ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:stable
Digest: sha256:34dcfa54a477222e583d0992d719d1f18b1699c66c25883cdb00635ee14646af
Version: 43.20260303.1 (2026-03-03T07:07:02Z)
SecAdvisories: 3 unknown severity, 1 low, 6 moderate, 5 important
Diff: 700 upgraded, 46 removed, 12 added
LayeredPackages: btrfs-assistant
โ ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:stable
Digest: sha256:7d43ab5c2c9107a6d7ea89f9f198fad5415c5614a37a0c119dbbe59a3d3857c3
Version: 43.20260203 (2026-02-03T02:04:01Z)
Digest: sha256:5e7f3ee96ed39ad9bb84de9c3ab7f110e8dfeb779b5ef91e77a4e29d4d376f2a
Version: 43.20251230 (2025-12-30T02:10:00Z)
inffy
March 8, 2026, 4:39pm
5
pkill bazaar and then try again
Are you on the newest update?
EDIT: Looking at the bug report you are not rebooted to the newest image. We have disabled the bazaar.service background service on the newer images because for some people it caused issues.
rebooting now, will report back
@inffy that solved my issue, thanks a lot, i will link here on the issue on github
