I had to tangle with Bazzite for a few hours to get it working; but this is me posing a question if there is a better method of doing this.
I have a game I want to install and the game is Asheron’s Call. It’s a dead MMORPG with a passionate fan base so big that they still post tutorial videos how to do quests on Youtube since every quest is left unmarked since day one the game became available. (You had to interact with the community and the world to figure out the quests and it’s a feature no NEWER MMORPG’s take advantage of, not even RuneScape)
To get Asheron’s Call to work properly, you need to install 2 program’s and replace a set of files in the game’s root folder. The first program is just installing the client; which is easy to do with Wine and Bazzite’s pre-fix. The second program is the ThwargLauncher and it’s here I ran into issues as I ran to install it, but it did not launch or run the game client to connect to a server.
Being a beginner and discovering that wine put both in their own “boxed” environment to run the program’s as separate, I had to painstakingly move the files from the launcher’s “box” into the client’s “box” and learned quickly how to change the Wine Prefix to aim at the Modded Launcher to get it to run.
But dealing with this and Bazzite; I got to ask if there is an easier way to direct WINE or any of the prefix install’s to the original folders I install a Windows Application, especially a game, to install into THAT folder/directory and NOT HAVE IT create a new directory or boxed environment FOR THAT app? Because it feels like it’s creating more bloat and I have a few classic titles to install which range from patches to upgrade’s and there are other Windows Applications that have this type of setup.
