Zellij does not copy to clipboard in Ptyxis
I ran brew install zellij, then journalctl -r, tried to copy some output, but it fails to copy.
When I check /tmp/zellij-1000/zellij-log/zellij.log, I can see that every time I try to copy something, it tells me:
ERROR  |zellij_utils::input::layo| 2024-12-15 01:36:21.662 [screen    ] [zellij-utils/src/input/layout.rs:1124]: Failed to read layout dir: Os { code: 2, kind: NotFound, message: "No such file or directory" }
My terminal emulator is ptyxis. This is my first time experiencing this issue with Zellij, and I suspect it must be something to do with homebrew…
Okay, I was completely wrong. Clipboard copy is broken in Ptyxis and Black Box, but when I tested in Konsole, it worked. I also tried Ptyxis on my Arch machine and it similarly failed to copy (though with a different error).
It seems like these terminal emulators aren’t emitting the correct sequence for clipboard copy to work in Zellij.
It also doesn’t work in GNOME Terminal.
Apparently this is due to VTE, the underlying library all these terminal emulators rely on, not supporting the feature: Copying terminal output not working via SSH (lack of OSC 52 support) (#185) · Issues · Christian Hergert / ptyxis · GitLab
If you’re a Zellij user and you want this feature (you definitely want this feature), layer on Alacritty or install Konsole via Flatpak. These are the only other terminal emulators I know that work with Zellij.
I use wezterm (installed via flatpak) with Zellij and it also works with Zellij’s selection-copy behavior.
I ended up using Konsole, the Flatpak. And you must use the Konsole Flatpak, because the RPM Konsole version in the base system doesn’t work with the selection-copy behavior (at least on Kinoite)!
I’m curious as to why. Surely it’s not because Konsole only recently gained support for the behavior and the Flatpak is newer?
