WireGuard config Split Tunneling on Bluefin
Scenario - imported WireGuard config.
Have you guys found a way to do VPN split tunneling on Bluefin?
Split Tunneling is the ability to exclude or include certain apps to go through WireGuard vpn config.
I’ve gotten this to work by editing the VPN connection, and in the IPv4 tab, turning on “Use this connection only for resources in its network”.
Then the apps that I want to use the VPN, I specifically configure to use only the VPN’s network interface.
