Installing Bluefin onto a Framework Laptop 16
This document has moved here:
Hello @Matt_Hartley here within the Ublue Community!
Good to have you here!
I’m so happy i got a FrameWork! And to find a home in Ublue! Best combination!
To a great future :partying_face:
In the future, I may end up installing Aurora or Bazzite to a Framework 16 as I begin selling off project devices to afford one. With that in mind, is there a simple way for me to install and setup Mullvad VPN on there without using something like a Wireguard config? I enjoy the ease of use of being able to install the Mullvad VPN and select wherever I want for my location in their app.
Thanks appreciate it. :slightly_smiling_face:
I have layered the RPM for ExpressVPN, I’d assume that one is doable as well. Easy peasy. :sunglasses: rpm-ostree.
If layered, it would be able to rout systemwide networking through the VPN, correct? If so, that’s rad.
You’d want to dns leak test, but yeah. I assume for wireguard, wg0.
Hi all, want to confirm: there is no longer a Framework specific ISO, correct?
For future visitors to this post, it might be worth updating the initial screenshot to show the new screen:
