I installed bazzite following the instructions in a YouTube video
I installed decky loader in desktop mode
Then I installed the hhd decky plugin
I set up a custom fan curve in HHD(TDP is also custom)
But when I played the game, the fan didn’t work as I set it, its speed was low, and even though the CPU temperature was gradually rising, it didn’t increase the speed,It’s like a constant speed. I had to turn off the custom fan or the CPU would overheat.
I don’t know why this is, does anyone know what else I need to install to make it work?
Thanks for your help,
I used HHD to adjust the fan, but it didn’t work
when I was installing the system, the ACPI bios error code appeared on the startup screen, I tried to skip it and then installed the system.
I wonder if this has anything to do with the fact that I didn’t unplug the battery when I replaced the hard drive.
I searched some information, ACPI ERROR may be related to power management
