Hello everyone! I recently switched to this wonderful distribution. However, I decided to reinstall the system to remove unnecessary stuff and keep it clean. I really liked the blur and transparency effect in the default Vapor theme. Before this, I had only seen something like that on Windows 7, and here it looked so beautiful that it convinced me to stay on this system.
But yesterday I noticed that the transparency in the Vapor theme disappeared, and the panel itself turned dark gray. I tried everything I could, but nothing worked. Maybe you can help me?
Here’s what I tried:
Enabled the Translucent effect for the panel;
In the settings: System Settings / Window Management / Blur — I changed every option available;
Also switched themes, but nothing helped.
