Hi!
I installed Bazzite and I really like it, but I installed Zen Browser and cannot get it to have blur effects.
First when I installed it the theme was just black
Then I tried enabling “zen.widget.linux.transparency" in about:config, but that makes it completely transparent, not blurry:
Does anyone know how to fix this? I am really new to Bazzite
thank you
Is Zen Browser installed as a Flatpak? You might have to enable GPU acceleration. You can do this in Flatseal.
Sadly didn’t work
thank you for replying though
Cautious about trying this since it says the Fedora one (I assume that’s the correct one for Bazzite) is unofficial… Thanks though
might just keep it without blur but with a gradient instead, even though it doesn’t look as cool lol
