Brightness setting disappeared
Hi dear ones,
The display brightness setting has recently disappeared from the taskbar under brightness and color. What can I do?
You can still adjust it using F2 and F3, but it’s still stupid
I’m very happy about your help.
Kind regards,
The brightness settings in your system tray might have been accidentally set to disabled. Try right clicking on the system tray and selecting “Configure System Tray.”
I am using Bazzite GNOME and I have the same issue where my brightness setting disappeared after last update. How do I find that “Configure System Tray”?
