Hi,
I installed WireGuard tools with Brew.
I have the file mentioned in /etc/wireguard.
Using the quick-connection-command with the provided configuration file (with the keys) doesn’t work. I looked for /dev/fd/63 and I don’t seem to have a file or folder named 63 in that place.
❯ sudo wg-quick up belgie
[#] ip link add belgie type wireguard
[#] wg setconf belgie /dev/fd/63
Name or service not known: `undefined.vpn.mega.nz:51820'
Configuration parsing error
[#] ip link delete dev belgie
I’m following this guide from MEGA (I have their VPN):
In the meantime, you could generate the VPN credentials, to be used in the WireGuard client for Linux. In order to do that, please refer to the guide below:
- Access Installation - WireGuard and download the version that matches with your system.
Copy the install command from the site and paste it in your Linux terminal. Note that the system will request your admin password.
- Access your MEGA account through a browser, then navigate to Settings - VPN (or click here MEGA).
On the credential section, select the country you want to connect and click on ‘Generate VPN credentials’.
The system will create a QR code with a download button, please download the credential.
- On your Linux system, open /etc and open the Wireguard folder (note that this is a system folder, therefore, it will be necessary to enter your administrator credentials).
Copy the VPN file from the location you downloaded it and paste it in the Wireguard folder.
Note that we recommend you rename the file name to one that you will easily identify. I.e. Spain if you create a credential to connect to Spain.
- Open your terminal and execute the command sudo wg-quick up ‘vpn filename’
This will connect your VPN.
Note: ‘vpn filename’ has to be introduced without apostrophes ('), and without the extension file name. E.g., to use ‘Spain.conf’ file, please introduce ‘wg-quick up Spain’
If during the connection attempt the system returns with an error /usr/bin/wg-quick: line 32: resolvconf: command not found then it means that your system will need an additional package for the VPN.
Simply execute sudo apt install openresolv to install the missing package.Once installed, please execute the connection command again.
To disconnect the VPN, simply execute sudo wg-quick down ‘vpn filename’
EDIT:
This is the conf-file:
[Interface]
PrivateKey = xxxx
Address = xxxxx
DNS = xxxx
[Peer]
PublicKey = xxxxx
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = undefined.vpn.mega.nz:51820
So that Endpoint is the problem, but I can’t find the correct address by websearching.
