Update failed and now having issues booting
While using topgrade, I got the following error while progress was running:
[3/4] Upgrading mesa-vulkan-drivers-0:24.3.4-3.fc41.x86_64 100% | 335.1 MiB/s | 105.2 MiB | 00m00s
[RPM] unpacking of archive failed on file /usr/share/vulkan/icd.d/broadcom_icd.x86_64.json;679dcae4: cpio:
Unpack error: mesa-vulkan-drivers-0:24.3.4-3.fc41.x86_64
This was the full terminal output after topgrade:
── 09:18:27 - System update ────────────────────────────────────────────────────
Note: This system is image (rpm-ostree) based.
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia:stable
Checking out tree 072dabd… done
Enabled rpm-md repositories: copr:copr.fedorainfracloud.org:ilyaz:LACT copr:copr.fedorainfracloud.org:rodoma92:kde-cdemu-manager copr:copr.fedorainfracloud.org:rodoma92:rmlint copr:copr.fedorainfracloud.org:rok:cdemu updates fedora copr:copr.fedorainfracloud.org:codifryed:CoolerControl updates-archive
Importing rpm-md… done
rpm-md repo ‘copr:copr.fedorainfracloud.org:ilyaz:LACT’ (cached); generated: 2025-01-16T07:49:04Z solvables: 12
rpm-md repo ‘copr:copr.fedorainfracloud.org:rodoma92:kde-cdemu-manager’ (cached); generated: 2024-10-29T12:13:12Z solvables: 16
rpm-md repo ‘copr:copr.fedorainfracloud.org:rodoma92:rmlint’ (cached); generated: 2024-10-29T12:31:09Z solvables: 4
rpm-md repo ‘copr:copr.fedorainfracloud.org:rok:cdemu’ (cached); generated: 2024-10-21T13:15:21Z solvables: 23
rpm-md repo ‘updates’ (cached); generated: 2025-02-01T05:26:14Z solvables: 19132
rpm-md repo ‘fedora’ (cached); generated: 2024-10-24T13:55:59Z solvables: 76624
rpm-md repo ‘copr:copr.fedorainfracloud.org:codifryed:CoolerControl’ (cached); generated: 2024-12-15T04:11:31Z solvables: 6
rpm-md repo ‘updates-archive’ (cached); generated: 2025-02-01T06:02:46Z solvables: 27453
Resolving dependencies… done
No upgrade available.
── 09:18:49 - Distrobox ────────────────────────────────────────────────────────
Upgrading fedora…
Starting container… [ OK ]
Installing basic packages… [ OK ]
Setting up devpts mounts… [ OK ]
Setting up read-only mounts… [ OK ]
Setting up read-write mounts… [ OK ]
Setting up host’s sockets integration… [ OK ]
Setting up host’s nvidia integration… [ OK ]
Integrating host’s themes, icons, fonts… [ OK ]
Setting up distrobox profile… [ OK ]
Setting up sudo… [ OK ]
Setting up user’s group list… [ OK ]
Container Setup Complete!
distrobox: Installing basic packages…
/usr/bin/dnf
Updating and loading repositories:
Repositories loaded.
Package Arch Version Repository Size
Upgrading:
mesa-vulkan-drivers x86_64 24.3.4-3.fc41 updates 105.2 MiB
replacing mesa-vulkan-drivers x86_64 24.3.3-2.fc41 7e5c8250c1944e36a2f10b854f0 104.2 MiB
Transaction Summary:
Upgrading: 1 package
Replacing: 1 package
Total size of inbound packages is 19 MiB. Need to download 0 B.
After this operation, 997 KiB extra will be used (install 105 MiB, remove 104 MiB).
[1/1] mesa-vulkan-drivers-0:24.3.4-3.fc41.x86_64 100% | 0.0 B/s | 0.0 B | 00m00s
Already downloaded
[1/1] Total 100% | 0.0 B/s | 0.0 B | 00m00s
Running transaction
[1/4] Verify package files 100% | 21.0 B/s | 1.0 B | 00m00s
[2/4] Prepare transaction 100% | 42.0 B/s | 2.0 B | 00m00s
Transaction failed: Rpm transaction failed.
Error: An error occurred
── 09:19:02 - Firmware upgrades ────────────────────────────────────────────────
Updating lvfs
Downloading… [ - ]
Successfully downloaded new metadata: 1 local device supported
Devices with no available firmware updates:
• AFOX SSD 480GB
• HS-SSD-Desire(P) 512G
• SP900
• ST500LT012-1DG142
• System Firmware
• TS128GSSD340
Devices with the latest available firmware version:
• UEFI dbx
No updates available
── 09:19:02 - Flatpak User Packages ────────────────────────────────────────────
Looking for updates…
Nothing to do.
── 09:19:02 - Flatpak System Packages ──────────────────────────────────────────
Nothing to do.
── 09:19:03 - pip3 ─────────────────────────────────────────────────────────────
Requirement already satisfied: pip in /home/Chronoflare/.local/lib/python3.13/site-packages (25.0)
── 09:19:04 - Mozilla GNOME Themes ─────────────────────────────────────────────
── 09:19:04 - Third Party CSS Loader Themes ────────────────────────────────────
── 09:19:04 - Summary ──────────────────────────────────────────────────────────
System update: OK
distrobox: IGNORED
Firmware upgrades: OK
Flatpak: OK
pip3: OK
Mozilla GNOME Themes: OK
Third Party CSS Loader Themes: OK
en-ZA.
(R)eboot
(S)hell
(Q)uit
So thinking that clearing the cached packaged might help I used: rpm-ostree cleanup -m and then retried running topgrade.
This caused the system to get stuck on updating metadata for fedora at 95% with 0sec remaining, I fear the system is unstable so I refuse to shutdown at this point, can anyone help?
This is an errant distrobox that’s failing (your fedora one), not your system.
But after this failed update, I needed to roll back to a previous update, else the system just doesn’t boot at all, is it something I can fix on my side? Or should I be waiting for a fix?
That error is unrelated to the nvidia issue that was reported earlier today, can you try running an upgrade again?
Might have been related though, using NVidia GPU myself.
ujust update
returned a failure based on timestamp difference as well as using
rpm-ostree update
However, appending --allow-downgrade to rpm-ostree update succeeded in installation of a previous version and now the PC boots fine.
Thank you so much for the help
