I reported a Kernel Panic yesterday and I’ve heard there is a fix, but I’m getting an error when trying to update:
Note: This system is image (rpm-ostree) based.
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia:stable
error: While checking against deployment timestamp: Upgrade target revision 'bcee6724ab2bc04b6b38fde4131f1794d117c21d93104c6a40329e2c61a93c80' with timestamp 'Mon 27 Jan 2025 05:43:17 UTC' is chronologically older than current revision '8c295ace70bd999151270ad536187893ce70e8fcea72463472a754b976f44f0e' with timestamp 'Fri 31 Jan 2025 05:19:58 UTC'; use --allow-downgrade to permit
System update failed:
0: Command failed: `/usr/bin/sudo /usr/bin/dnf upgrade -y`
1: `/usr/bin/sudo` failed: exit status: 1
src/steps/os/linux.rs:259
Retry? (y)es/(N)o/(s)hell/(q)uit
Here is my status again:
rpm-ostree status
State: idle
AutomaticUpdates: check; rpm-ostreed-automatic.timer: inactive
Deployments:
Digest: sha256:61957bf6a9d1e05ef8dcc4370113b8c0fb2387eabf2e01fd4e7cc37524d5b9a2
Version: 41.20250131 (2025-01-31T05:19:58Z)
Diff: 55 upgraded, 2 removed, 1 added
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia:stable
Digest: sha256:3ae3d2fc0d8e33ee187b78e7abc68ffe4a1b69f83957a56ae37f6ee4905319ee
Version: 41.20250127 (2025-01-27T05:43:17Z)
I’ve searched this forum, the Answer Overflow and the web but cannot find what to do next. Any help, please?
