When I launched ujust upgrade it installed pip locally for my user:
❯ which pip
~/.local/bin/pip
❯ stat .local/bin/pip
File: .local/bin/pip
Size: 220 Blocks: 8 IO Block: 4096 regular file
Device: 0,42 Inode: 482165 Links: 1
Access: (0755/-rwxr-xr-x) Uid: ( 1000/ devoops) Gid: ( 1000/ devoops)
Context: unconfined_u:object_r:gconf_home_t:s0
Access: 2024-06-07 16:10:58.758464874 +0400
Modify: 2024-06-07 16:10:58.747464780 +0400
Change: 2024-06-07 16:10:58.747464780 +0400
Birth: 2024-06-07 16:10:58.747464780 +0400
But my system already had global pip installed:
❯ stat /usr/bin/pip
File: /usr/bin/pip
Size: 221 Blocks: 8 IO Block: 4096 regular file
Device: 0,34 Inode: 115745 Links: 10
Access: (0755/-rwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Context: system_u:object_r:bin_t:s0
Access: 2024-06-05 12:10:38.886578649 +0400
Modify: 1970-01-01 04:00:00.000000000 +0400
Change: 2024-06-07 11:13:15.038553824 +0400
Birth: 2024-06-05 12:10:38.886578649 +0400
Is this the intended behaviour of updating system via ujust? I haven’t seen other Linuxes installing pip in ~/.local/bin before, so that’s kinda strange
