Errors updating with 'ujust update'
I’m unable to update Bluefin for some reason. Here’s what I’m getting after running ‘ujust update’.
── 06:58:02 - System update ────────────────────────────────────────────────────
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx:stable
Checking out tree f670486... done
Enabled rpm-md repositories: updates fedora copr:copr.fedorainfracloud.org:hikariknight:looking-glass-kvmfr rpmfusion-free-updates rpmfusion-free google-chrome rpmfusion-nonfree-nvidia-driver rpmfusion-nonfree-steam copr:copr.fedorainfracloud.org:phracek:PyCharm 1password updates-archive
Importing rpm-md... done
rpm-md repo 'updates' (cached); generated: 2024-11-13T03:08:04Z solvables: 8660
rpm-md repo 'fedora' (cached); generated: 2024-10-25T08:41:19Z solvables: 76624
rpm-md repo 'copr:copr.fedorainfracloud.org:hikariknight:looking-glass-kvmfr' (cached); generated: 2024-10-25T08:11:34Z solvables: 5
rpm-md repo 'rpmfusion-free-updates' (cached); generated: 2024-11-09T12:46:29Z solvables: 26
rpm-md repo 'rpmfusion-free' (cached); generated: 2024-10-27T07:49:25Z solvables: 347
rpm-md repo 'google-chrome' (cached); generated: 2024-11-12T22:57:42Z solvables: 4
rpm-md repo 'rpmfusion-nonfree-nvidia-driver' (cached); generated: 2024-11-04T07:30:59Z solvables: 17
rpm-md repo 'rpmfusion-nonfree-steam' (cached); generated: 2024-10-03T14:20:29Z solvables: 2
rpm-md repo 'copr:copr.fedorainfracloud.org:phracek:PyCharm' (cached); generated: 2024-08-12T11:59:47Z solvables: 5
rpm-md repo '1password' (cached); generated: 2024-11-12T16:09:18Z solvables: 2
rpm-md repo 'updates-archive' (cached); generated: 2024-11-13T03:45:01Z solvables: 7647
 Problem: conflicting requests
  - nothing provides system-release(40) needed by rpmfusion-free-release-40-1.noarch from @commandline
System update failed:
   0: Command failed: `/usr/bin/rpm-ostree upgrade`
   1: `/usr/bin/rpm-ostree` failed: exit status: 1
   src/steps/os/linux.rs:232
Retry? (y)es/(N)o/(s)hell/(q)uit
I also tried rebasing to an earlier build and then rebasing to stable but am still having issues. Rebasing to an earlier build works but not to stable.
Which Tag would you like to rebase to?
The default selection is gts, stable (weekly builds) and stable-daily (daily builds) are for enthusiasts, and latest is for testers
Rebase Target is ghcr.io/ublue-os/bluefin-dx:stable
Confirm Rebase
Choose your action.
Choose:
> rebase
  cancel
You need to reset your layers.
Also why do you have rpmfusion repos layered?
Update: After running sudo bootc switch ghcr.io/ublue-os/bluefin:stable --enforce-container-sigpolicy and rebooting, it finally updated. Not sure what caused the issue in the first place.
No idea how it ended up like that
