See the probe: https://linux-hardware.org/?probe=193b57e85f
This driver only available on TUXEDO OS’s repos.
After I installed the driver from TUXEDO OS’s repos on POP OS, CachyOS, the ethernet works.
But I didn’t tested this on Bazzite because I can’t use rpm-ostree in live mode.
And also, university wifi connections (eduroam etc.) doesn’t work on Bazzite and CachyOS. I search online and find a fix: “nmcli con mod id <YOUR_SSID> 802-1x.phase1-auth-flags 32”.
Here is the discussion where I found the fix’s link: University Wifi Connectivity issues - #3 by B80
The same issue was on the CachyOS too, but works directly on TUXEDO OS.
