[Solved] Started Bazzit but all of a sudden wifi does not work anymore
So I fired up my bazzite which was working fine until today.
Wifi does not work anymore as of now. Bluetooth does.
I do not know why wifi would stop working, since there wer no changes as far as my knowledge is concerned.
That to me is a huge bug.
When you start your PC, your PC boot in GRUB and then you can boot into the older version.
If the wifi works fine in the older version, then there’s a regression in the new update.
Yes true but I realised, that my wifi-chip is not being recognized by other Linux OS’s I have installed.
From the moment, I opened this thread I wiped my ssd clean and installed Fedora and Debian but none of them were able to recognize my wifi.
However, my first and last question is: Does the MOK potentially prevent the modules from being loaded?!
But that has nothing to do with the Kernel to properly recognnize the wifi chip, which he does not.
Anyways, I think the wifi chip has a defect and will direct all further investigation to that point with the distrubutor/vendor.
I do not see any obvious reason, why a Linux kernel like 6.16.x oer 6.17.x might not be able to recognize the wifi chip properly, if it was not defect.
Currently, it seems like the update of Bazzie bricked something…
Is there a TPM system somewhere in Bazzite active.
I did a reflashing of my motherboard and afterwards, bazzie would not load up since something could be be loaded…
What is going on here?
If you reflashed your bios, Secure Boot probably defaulted to active. Try disabling it in bios and you sould be able to boot again. Same thing happened to me when I updated bios.
If that is the issue (check docs first), after disabling secure boot you may also need to re-enroll the secure boot key for universal blue. This happened to me recently as well with a bios update. You can use a ujust command to re-enroll the mok.
Follow the instructions per the docs, method B:
Hi guys,
Thanks for all the replies! I did enroll the MOK again but this also did not solve the issue.
In this case after investigation with the vendor and reseller, the wifi chip appears to be defect, which is why I teared down my “fuckinggaminghard” AMD 9950X3D, RTX5080, 64GB RAM, Samsung 990 Pro 1TB and Kioxia 2 TB SSD and got that motherboard out of the chassis to send it back to the reseller.
Stuff is standing here torn down and waiting for a new white motherboard to arrive.
Update on this one:
There has no hardware defect been detected. Wifi chip is not defect, it has to be something to do with Bazzite ;(
Okay, this means, if the problem persists, I will have to leave Linux behind and go for Windows. Saf but if this is the result of the investigation, then this is the cold bitter truth.
Hi guys,
Kindly let me know:
  1. where can I find the MOK ?
  2. How to delete that crap ?
  3. Can I use Bazzite without that?
Causing too many problems… I will not tolerate that.
I am awaiting my motherboard back shortyl and will prepare now for Windows to be on it.
If you are still on linux…. you can use the sudo mokutil --reset command from the terminal to remove any and all secure boot keys from your system. If you are moving back to windows then that would be the easiest option.
If you are not using secure boot (disabled in bios) you do not need the MOK for everything to work normally (assuming no other underlying issues, which may be the case here).
If you are back on windows now, you can also go into the bios and deal with this. The specific instructions will vary from manufacturer to manufacturer…so check your motherboard manual or go to their website for instructions.
Be sure to turn off bitlocker in windows (if it is on) before doing this or make sure you have recovery keys handy as windows may require these to get back in to your system.
The process is typically something like: removing all secure boot keys, reset your computer and then re-enroll the default secure boot keys, and then reset again.
Note: I cannot say for certain if your issue is actually a secure boot specific one… and I am instead leaning towards the possibility of an ongoing issue with a particular wifi chip (mediatek mt7922 wifi) that has functionality issues after some recent kernel updates…. you may need to physically inspect to your motherboard to see the model name if that specific chip or related family of chips is installed on your motherboard.
updated bug:
original bug:
Dear Icewall,
Good to have you involved and thanks for your efforts!
Current status is:
Just a copple of hours ago, I received my motherboard back from reseller.
They have checked it. We are talking about the MSI B850 TI EDGE WiFi → https://download-2.msi.com/archive/mnu_exe/mb/MPGB850EDGETIWIFI_English.pdf
The wifi chip involved here is Qualcomm QCNCM865 Wi-Fi 7 as far as the resources on the internet tell me.
I am still running Bazzite and firstly disabled the secure boot since I got the respective error message which is stated in the MOK enroll guide. → Secure Boot Instructions - Bazzite Documentation
I was then able to boot and confirmed my wifi was working. The vendor tested with Windows and was not able to find an issue after intense testing.
I then did the re-enrollment of the MOK, using the ujust-security-enroll command as stated in the Secure Boot Instructions after the installation.
The enrolled without issues, I enabled the secure boot and wifi was working.
These information cover your thoughts, that this has nothing to do with the MOK.
As per my opinion, Bazzite has an issue with the qualcom wifi and ethernet drivers. Since I currently face issues with using ethernet. My ethernet adaptor would work for a copple of minutes after booting and then would fail for some reasons.
Long story short:
Yes, since I never activated secure boot (until today, a copple of minutes ago) there is no obvious reason why wifi should fail.
The motherboard age is 4 weeks, so hardware fail does not seem to be likely. However, please note, that I have discussed this matter with the certified support of MSI who told me to leave the mainboard without any power for about 15 minutes. That is suspicious to me, if you would ask me!
Also I think Bazzite has an issue with the ethernet and/or wifi drivers, for the reasons mentioned above.
I am still running bazzite and will keep a close eye on this matter and will update you guys here.
Edit ***
Now I am on my Bazzite FuckingGamingHard-Machine :smiley:
Silly name, I know but I think it is funny… Anyways, these are the outputs of the most important commands to show the system details:
andybee@bazzite:~$ uname -a
Linux bazzite 6.17.7-ba01.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Sun Nov  2 16:22:16 UTC 2025 x86_64 GNU/Linux
andybee@bazzite:~$ lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Internal GPP Bridge to Bus [C:A]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Internal GPP Bridge to Bus [C:A]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation GB203 [GeForce RTX 5080] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 22e9 (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller S4LV008[Pascal]
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Upstream Port (rev 01)
04:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:00.0 Network controller: Qualcomm Technologies, Inc WCN785x Wi-Fi 7(802.11be) 320MHz 2x2 [FastConnect 7800] (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8126 5GbE Controller (rev 01)
09:00.0 SATA controller: ASMedia Technology Inc. ASM1064 Serial ATA Controller (rev 02)
0b:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 800 Series Chipset USB 3.x XHCI Controller (rev 01)
0c:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset SATA Controller (rev 01)
0d:00.0 Non-Volatile memory controller: KIOXIA Corporation Exceria Pro NVMe SSD (rev 01)
0e:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Granite Ridge [Radeon Graphics] (rev c9)
0e:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Radeon High Definition Audio Controller [Rembrandt/Strix]
0e:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h PSP/CCP
0e:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 3.1 xHCI
0e:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 3.1 xHCI
0e:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller
0f:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 2.0 xHCI
andybee@bazzite:~$ lscpu
Architecture:                x86_64
  CPU op-mode(s):            32-bit, 64-bit
  Address sizes:             48 bits physical, 48 bits virtual
  Byte Order:                Little Endian
CPU(s):                      32
  On-line CPU(s) list:       0-31
Vendor ID:                   AuthenticAMD
  Model name:                AMD Ryzen 9 9950X3D 16-Core Processor
    CPU family:              26
    Model:                   68
    Thread(s) per core:      2
    Core(s) per socket:      16
    Socket(s):               1
    Stepping:                0
    Frequency boost:         enabled
    CPU(s) scaling MHz:      37%
    CPU max MHz:             5756,4521
    CPU min MHz:             624,1940
    BogoMIPS:                8599,98
    Flags:                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good amd_lbr
                             _v2 nopl xtopology nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy s
                             vm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpuid_fault cpb cat_l3 cdp_l3 hw_pst
                             ate ssbd mba perfmon_v2 ibrs ibpb stibp ibrs_enhanced vmmcall fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflus
                             hopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local user_shstk avx_vnni avx512_bf16 clzero irperf xsav
                             eerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif x2avic v_spec_ctrl
                              vnmi avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid bus_lock_detect movdiri movdir64b overflow_recov succor smca
                              fsrm avx512_vp2intersect flush_l1d amd_lbr_pmc_freeze
Virtualization features:
  Virtualization:            AMD-V
Caches (sum of all):
  L1d:                       768 KiB (16 instances)
  L1i:                       512 KiB (16 instances)
  L2:                        16 MiB (16 instances)
  L3:                        128 MiB (2 instances)
NUMA:
  NUMA node(s):              1
  NUMA node0 CPU(s):         0-31
Vulnerabilities:
  Gather data sampling:      Not affected
  Ghostwrite:                Not affected
  Indirect target selection: Not affected
  Itlb multihit:             Not affected
  L1tf:                      Not affected
  Mds:                       Not affected
  Meltdown:                  Not affected
  Mmio stale data:           Not affected
  Old microcode:             Not affected
  Reg file data sampling:    Not affected
  Retbleed:                  Not affected
  Spec rstack overflow:      Mitigation; IBPB on VMEXIT only
  Spec store bypass:         Mitigation; Speculative Store Bypass disabled via prctl
  Spectre v1:                Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:                Mitigation; Enhanced / Automatic IBRS; IBPB conditional; STIBP always-on; PBRSB-eIBRS Not affected; BHI Not affected
  Srbds:                     Not affected
  Tsa:                       Not affected
  Tsx async abort:           Not affected
  Vmscape:                   Mitigation; IBPB on VMEXIT
andybee@bazzite:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 0db0:cd0e Micro Star International USB Audio
Bus 001 Device 004: ID 0db0:0076 Micro Star International MYSTIC LIGHT
Bus 001 Device 005: ID 0489:e10a Foxconn / Hon Hai
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 007 Device 003: ID 3554:fc06 CX 2.4G Receiver
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Please find the most importand information about the wifi chip:
Currently Bazzite, I mean the Kernel seems to recognize the wifi chipset, which was not the case by the time I opened this threat. I tried to cover the issue with my elgato: https://youtu.be/lAOt8V-g5fs
The video quality is kind of poor for whatever reason on yt. The original video on the other hand has high resolution. I was not able to find the reason, why youtube would scale it down to SD quality.
Well that is some good detective work :+1: hats off to you!
I guess I was way off on the chip model :sweat_smile:…sorry about that.
So there are a couple things I discovered when I checked out that particular wifi chip:
There was an issue upstream with fedora, should have been fixed already in 42…I wonder if another regression occurred in 43…here is what I have found after jumping down the rabbit hole…:sweat_smile: :
A couple of posts from a while back:
The upstream fedora bug report page:
You may want to add on to the bug report upstream or open an issue on github for bazzite here: GitHub · Where software is built
The discussion page:
Not sure if any of the wifi tips from the docs page (near bottom of page) might help this time, but I will leave this here just in case:
P.S. During the first 30 minutes (sometimes much less) of posting a video on youtube…it is still processing so it looks very low resolution and blurry/pixelated. This goes away after that period. Right now it is at 720p and looks fine :+1: .
Hope something from this pile of stuff was helpful…:sweat_smile: ….cheers!
Hi Icewall,
Okay, yes, that was very helpful.
I was always using Bazzite kernel 6.16.x-fc42 & current Bazzite Kernel 6.17.7-fc***
What really bakes my noodle is, that I tested several other distress like Debian, Fedora WS42 and Leap 16 and all of them were unable to detect my wifi chip.
Weide but the issue defenitly is kernel related.
I will open a case on the bus tracker as you stated, although I do not have any wifi issues at this very moment with kernel 6.17.7
But since my issue occurred during update just like the other guy posted, the next update will come and break my wifi.
This leads to the logical question of how to compile the lots kernel 6.12.57 for bazzite.
But that is an issue for another thread.
Case closed since these truths applied:
  1. Update from Bazzite kernel 6.16.x to Bazzite Kernel 6.17.7. triggered the incident
  2. Unknown why other Linux Distros were unable to recognize the wifi chip when installed brand new.
  3. Only windows was able to get a grip and using the vendors drivers made the chip work again. → My gutsfeeling tells me, that the chip was set to a specific state after the Bazzite Update form 6.16.x to 6.17.7. which is why windows only was able to get the chip back into normal mode via installing the drivers.
    → I do not know how to proof that. Please let me know and I will conduct tests.
Solution here was to send it to vendor to install Windows and respective drivers.
Or in short:
  1. Delete Bazzite
  2. Install Windows with wifi drivers
  3. Delete Windows
  4. Install Bazzite ( with or without MOK )
Case closed.
In general, the kernel is the one that has the drivers for all your hardware.
So it can be that the 6.16 kernel had a bug/regression or the device driver wasn’t implemented, which would mean it wouldn’t recognize the wifi card.
So it propably was fixed in upstream on 6.17 or there was a firmware update for it that is now included in the bazzite kernel.
Its propably also the reason why other distros didn’t work, as most of them are using a way older kernel.
*** Edit ***
Created bug report here: Fedora update breaks Qualcom Wifi-7 chip ( Qualcomm Technologies, Inc WCN785x Wi-Fi 7(802.11be) 320MHz 2x2 [FastConnect 7800] (rev 01)) · Issue #3475 · ublue-os/bazzite · GitHub
*** Another Eedit ***
Currently the issue is re.-occuring again after I forcully halted my computer via pushing power button.
I think the solution now is to keep my computer wihtout power for about 15 Minutes or so.
I will try.
Wifi currently not being detected.
Final result:
Wifi works if I leave my pc for 15minutes without power.
Bazzite then recognizes the wifi again. See here:
Find the line: 07:00.0 Network controller: Qualcomm Technologies, Inc WCN785x Wi-Fi 7(802.11be) 320MHz 2x2 [FastConnect 7800] (rev 01)
andybee@bazzite:~$
I’m glad you found a workaround, sorry I could not be of more help.
And thanks for creating the github issue…it is important that the issues are documented so even if they can’t be fully fixed everyone can at least be aware of it.
But it all seems very strange…leaving computer off for 15 minutes fixes the problem…I hope future kernel updates will bring more stability for wifi.
