SELinux policy failure - missing policycoreutils-devel
I just setup my new work computer with Bluefin, and am loving it so far. The issue I have is that I need to install “ESET Management Agent” for security and compliance.
I’ve run the script, and it makes it all the way through, but then fails with the error:
“Failed to install SELinux policy due to missing dependencies (policycoreutils-devel).: Current locale settings are invalid”
In cockpit, I can see that the agent service is enabled, but has failed to start. I’ve updated the OS and rebooted just to be sure, but nothing changes. When I look at the support docs for ESET, it confirms that I need to install the package:
Install the policycoreutils-devel package:
yum install policycoreutils-devel (CentOS, Red-Hat, Fedora distributions)
I’ve checked, but policycoreutils is not available via brew, so I am assuming that I need to do something a bit more involved. Since I’m new to Bluefin, I’m unsure of how to proceed. Any advice?
Is the source to this script publically available so we can take a look?
looks like it is available via rpm-ostree -
% rpm-ostree search policycoreutils-devel
===== Name Matched =====
policycoreutils-devel : SELinux policy core policy devel utilities
Not sure what that pulls in but might be worth layering it via rpm-ostree install and see if the script completes?
The shell script that I was given does reference another shell script on the ESET CDN, but it looks to be encrypted. So, I believe the shell script I have is validating and running it, but I’m not able to see it in plain text.
So, it sounds like I need to use rpm-ostree install for that package and then run the script again. I didn’t know that was a thing! Thanks… I’ll give it a shot and report back.
This DID allow the script to complete, and now the service is listed… but it fails to start. I get this error in the logs:
eraagent.service: Control process exited, code=exited, status=203/EXEC
I think this might be a problem with permissions. So, the service is there and it tries to start, but it just fails with the 203 status.
Interesting note - I just tried disabling SELinux, and then starting the service… it works! Then I can enable SELinux again.
So, any ideas on what the issue may be?
Probably need to run restorecon on the files that were installed via that script.
