Hi
Currently running bluefin-dx on an old iMac, everything works fine except for screen sharing in google meet
Also opening a rdp session from a mac to the iMac does not appear to work either
In both cases it just produces a black screen
Apparently thisd is a known issue with gnome:
https://bbs.archlinux.org/viewtopic.php?id=283835
Any ideas how I could enable screen sharing?
Have you tried ujust fix-screenshare ?
j0rge
February 6, 2024, 7:23pm
3
What browser are you using for the gmeet screen sharing?
On Chrome
Version 121.0.6167.139 (Official Build) (64-bit)
Going to try the ujust command
Did not know it existed
j0rge
February 7, 2024, 4:16pm
5
That ujust command is unrelated (and broken I think we need to remove it). My app and tab sharing is working in gmeet and I have the same version of Chrome you have, so maybe it’s a configuration issue? Here are my flatseal settings if it helps:
Thx, let me compare settings
I just did a new install on a Macbook Pro and the screen sharing just worked
Will rebuild over the weekend and see what happens
