Remapping keys, how do you do it?
Hi there! I’m on Aurora and I wonder how do people remap keys. For some reason I can’t remap Ctrl to CAPS LOCK and Compose to Ctrl in Aurora using the built in Plasma Key Bindings.
When I set it it works in some cases and some not. In input fields these shortcuts do not work at all.
I got recommended GitHub - rvaiya/keyd: A key remapping daemon for linux., but I assume that would have to be installed by layering? Thoughts?
You could try ydotool. It’s included with bazzite so I’m assuming it’s on Aurora also.
https://github.com/ReimuNotMoe/ydotool
If you need something with a GUI Input-Remapper is awesome and I use it daily. Not sure if Aurora includes it, Bazzite does.
https://github.com/sezanzeb/input-remapper
Thanks. I should have added I need to use X11, so that won’t work.
