Problems with gaming ( resolution , keyboard)
hello ,i have problemst with the resolution in gaming ,i tryed 2 games ,dark souls on steam and civilisation 6 on epic game store.
The games look blurry i think its running with an low internal resolution ? change resolution in game does hardly anything.
I testet some applications on steam but the interface on the applications is tiny not readable.
And when i open the epic games launcher my keyboard does not recognize key presses every second or so , or its repeating keys, if i close epic laucher the problem goes away.
i use a nvidia rtx 4070 , and a monitor with 2.560 x 1.440 resolution ,keyboard is a be quiet light mount.
What version of bazzite did you pick? Sound like you maybe picket the Steam game mode version:
“Steam Gaming Mode is what SteamOS on the Steam Deck is built around. A simple interface that is controller-friendly built around Steam’s “Big Picture Mode” UI/UX. The minimal session only runs the bare minimum in the background, so most of the hardware resources is going towards the game being played. Gamescope is the main ingredient in Steam Gaming Mode which gives users options to set a framerate cap, resolution scaling options, etc.”
ref: Steam Gaming Mode Images - Bazzite Documentation
i use the desktop version
I just setup Bazzite last night on my PC. I am running 3060ti with Ryzen 5 3600 on Gnome, so it is a similar configuration.
I have a 4K monitor, and the scaling was set to 150%. When I opened Insurgency Sandstorm, the game was very blurry and weird.
I thought it was an issue with the game, but I later found out that it works perfectly fine if I set the monitor scale to 100%.
I see you have a 1440p monitor. Not sure what the scaling setting is out of the box for that, but I would check and see. (This is just in the Display settings)
I reinstalled with KDE instead and things worked better out of the box for me. Insurgency had no issues even with fractional scaling on.
thanks for the answers,
i set the scaling back to 100% and civilisation 6 is no longer blurry,but dark souls stay blurry.
i will try the KDE version, ty.
for the keyboard problem i found this ,its maybe a bug in the keyboard firmware:
i installed the kde version and there are no problems with the keyboard and resolution any more.
but the instalation was a pain ,the installer was at a wrong resolution i see only half of the screen and i have to tab and guess.
i have my tv and monitor conected to my pc , the first time i booting the tv was the primary ,i disabled my tv on the settings but on my monitor was no taskbar ,if i set my tv to primary the taskbar was on my monitior.had to make a new taskbar on my monitor and delete the taskbar on my tv then i can disable the tv in the settings.
And the fonts in kde are fuzzy and the letters are not “evenly” example : the M letter, one side of the M is tighter. i tryed different fonts and sizes ,aa off,sup pixel rendering and hinting nothing makes it better.
