Hi i recently installed bazzite and i like it very much so far! Unfortunately i cannot get steam to start :-(. It always has the message, that steamwebhelper is not responding. On EndeavourOS i could successfully start steam tho.
My PC (fastfetch screenshot)
I already tried rebasing to testing but without luck.
I hope you can help me, what logs should i provide?
Run bazzite-steam in the terminal and provide the output.
Sure, thanks!
Here’s the output:
Sorry, can’t just post it in here!
Small Update:
I found, that there is a flatpak version of steam in the store, that actually launches!
flatpak run com.valvesoftware.Steam INFO:root:https://github.com/flathub/com - Pastebin.com here’s the log in comparison, is there a big difference? the only thing it currently can’t do is, access my second hard drive, where my games are stored. But this is probably a flatpak specific
Hi there, you’ll have to specify the folder via Flatseal.
Close (Flatpak) Steam if it’s running. Open Flatseal → select Steam → enter the SteamLibrary path under “Other files”. Then when you relaunch Steam, you should be able to select it and eventually select it as default via Steam settings.
Thanks!
I had already tried this, but apparently i needed a restart for whatever reason? now at least my games folder is detected properly, let’s see if i could play games
