Steam no longer starts
Hello,
I recently have started using Bazzite on my main PC and so far I have had a flawless experience. However, recently I’ve had an issue with steam constantly logging me out.
I saw somewhere that apparently running ujust fix-reset-steam would help fix this issue, but it somehow ended up breaking my steam client completely. The login GUI doesn’t even appear in any capacity anymore and it seems like the steam process will run for a few seconds before terminating.
Just incase these are needed, I am including screen shots of fastfetch’s output and rpm-ostree status.
This is the output of ujust fix-reset-steam https://pastecode.io/s/w9bfvs89
Thanks for the help in advance!
Just in case, can you post the output of
df -h
From someone in the Discord you can try this:
Open terminal and run __GL_CONSTANT_FRAME_RATE_HINT=3 steam -reset
Let it reinstall and update Steam, once finished sign in/2FA into Steam. Then exit, launch Steam by clicking the desktop shortcut this time, it’ll ask you to re-log in/2FA. after you’ve logged in a second time, it should work from the shortcut again without asking you to sign in an additional time.
Running __GL_CONSTANT_FRAME_RATE_HINT=3 steam -reset has worked and oddly enough I didn’t need to log in twice.
Thank you both for your assistance! :grinning_face:
