Well. It basically does what’s in the title. Ujust script seems to fail to set up or update obs studio.
To add a little context I’ll just leave the error code
for what I see the problem lies in starting the container
ujust --choose
WARNING: This will assemble and replace the container obs-studio-portable
with the one defined in /etc/distrobox/apps.ini.
- Deleting obs-studio-portable…
Error: no such container obs-studio-portable
Cannot find container obs-studio-portable. - Creating obs-studio-portable…
Trying to pull Package obs-studio-portable · GitHub…
Getting image source signatures
Checking if image destination supports signatures
Copying blob b450bc6f6b29 done |
Copying blob f73e23b598ac done |
Copying blob 7fac97a5ccdb done |
Copying config 98b788e387 done |
Writing manifest to image destination
Storing signatures
98b788e387f917d5ba4aa6f4b3ef421f7b4c1583478e2bb4d37fa0e4ec26677e
Creating ‘obs-studio-portable’ using image Package obs-studio-portable · GitHub [ OK ]
Distrobox ‘obs-studio-portable’ successfully created.
To enter, run:
distrobox enter obs-studio-portable
Starting container… [ OK ]
Installing basic packages… Error: An error occurred
error: Recipe install-obs-studio-portable failed with exit code 1
This container has been broken for a while, we tried to get it going but it’s basically unmaintained, if someone is interested in maintaining it ping me and we’ll transfer the repo over to you. Sorry!
well. Good to know. I thought that might be my fault in messing with smth, but if it is a known bug, then I’ll just stick to flatpak version for now.
Cheers
