Distrobox and podman containers don't work any more
Distrobox and podman containers no longer work.
Error message: Error: unable to start container “ea0f1db2d4db2d9c89f9b8811f532e721f6f62682aabefe367d748a0551ac9ec”: crun: cannot stat /etc/hostname: No such file or directory: OCI runtime attempted to invoke a command that was not found
Not working since updating to image: Bluefin-dx;latest latest-41.20250319 a rollback solves the problem.
● Booted image: Package bluefin-dx · GitHub
Digest: sha256:bf7881a60bb66bd38d4294815e3da135d2f5ddac7853ae29825a4b10b034df08
Version: latest-41.20250319 (2025-03-19 05:05:48 UTC)
Rollback image: Package bluefin-dx · GitHub
Digest: sha256:1894338aa76266dcf69e03a9318299c1c1e83477d660affd771356200f6056d5
Version: latest-41.20250317 (2025-03-17 05:06:07 UTC)
Anyone else have this problem?
If so, how do we solve this?
Thanks,
Gordy
Per my article - Did You Know? How ostree update merges changes into etc and var - /usr/etc contains the version specific golden copy. I see a 0 byte file at /usr/etc/hostname when booted with 41.20250309.1 (bluefin-dx-nvidia:stable).
Based on what I learned while putting the article together I would not expect /etc/hostname to be touched if it has been modified.
Try resetting the hostname (using hostnamectl) and then switch back. It should not be touched.
Thanks for that, such a simple solution.
Gordy
