Hello, I installed bazzite on my onexfly 7840u and cannot figure out why I do not have sound from the internal speakers. Does anyone have any idea what I could do to fix this problem? I thought that maybe I installed bazzite wrong so I reinstalled and no dice. Thank you.
For my Asus ROG Ally, I had the same problem - no audio from internal speakers (audio was fine with a pair of plugged in headphones). Nothing I could do by changing settings in Bazzite helped.
Finally I found a hint through an issue on github: I upgraded the BIOS on my ROG Ally, and after that I have sound in speakers.
You machine seems very similar hardware, so perhaps something to look into.
Thanks for the reply, I eventually found the answer and it was the bios. I updated and now it works like a charm thanks!
