Need help, no audio from speakers
I just installed bazzite and it’s really awesome! But I have no audio coming from my speakers.
My setup includes the device’s own speakers and 3.5mm headphones.
There is no sound from the speakers, but there is sound from the headphones.
I tried looking for similar solutions on forums and github, but none of them worked for me.
My device is Ayaneo AIR 1S, This is the link to my hardware probe.
rpm-ostree status
deck@fedora:~$ rpm-ostree status
State: idle
Deployments:
  ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-deck:stable
                   Digest: sha256:c02ece6452dd8b2017f1e3b687f8107cccd0d8a7453399fd9b642df9cdb5cca9
                  Version: 40.20240502.0 (2024-05-02T23:42:25Z)
                     Diff: 12 added
          LayeredPackages: hw-probe
            LocalPackages: Geek1S-Audio-1.0-1.x86_64
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-deck:stable
               LiveCommit: 8bb0b14460bb671148914defa0f888651fcc7f23259e7794946c3234917f628f
                 LiveDiff: 12 added
                 Unlocked: transient
What is the output of amixer on your system? Specifically, I want to know which sound devices are detected. Alternatively, you can also run alsamixer and press F5.
Thanks for your reply.
I checked amixer and this is the output
deck@fedora:~$ amixer
Simple mixer control 'Master',0
  Capabilities: pvolume pswitch pswitch-joined
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 65536
  Mono:
  Front Left: Playback 65536 [100%] [on]
  Front Right: Playback 65536 [100%] [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch cswitch-joined
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 65536
  Front Left: Capture 65536 [100%] [on]
  Front Right: Capture 65536 [100%] [on]
That looks healthy. I suggest to try out the pavucontrol flatpak (org.pulseaudio.pavucontrol) to investigate which audio inputs and outputs you have and in particular, if the Master output needs to be switched to loudspeaker.
ye, I installed pavucontrol via flatpak and then checked the Master output, Master indeed the loudspeaker, ant it looks like it’s working but there’s no sound.
I found a discussion on Fedora, the problem looks very similar to mine and I’m referring to the solution in the discussion in the hope it helps.
Unfortunately this problem also existed when I was testing chimeraos and I found this discussion Ayaneo Air 1S support · Issue #755 · ChimeraOS/chimeraos · GitHub
I had this problem on HP Elitebook X laptop. I could change the volume but no sound from speakers. Eventually I ran alsamixer and there was something called “AMP speaker gain”. I raised it to -5.5dB and the sound appeared!
had this problem with my EPOS GSX 1000, and then found that despite the UI of the audio setting stating it was at full volume, alsameter showed it as being at 0 gain.
Upping that gain fixed it
i still have this problem on my laptop and it was at max in alsamixer,
here’s my laptop model: msi thin A15 B7VF
and i don’t know how to troubleshoot it :confused:
additional information:
$ pipewire
[E][10:17:02.675326] mod.protocol-native | [module-protocol-: 790 lock_socket()] server 0x5562162055c0: unable to lock lockfile '/run/user/1000/pipewire-0.lock': Resource temporarily unavailable (maybe another daemon is running)
[E][10:17:02.675597] pw.conf | [ conf.c: 602 load_module()] 0x5562161e5540: could not load mandatory module "libpipewire-module-protocol-native": Resource temporarily unavailable
[E][10:17:02.676444] default | [ pipewire.c: 124 main()] failed to create context: Resource temporarily unavailable
$ systemctl --user status pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: disabled)
Drop-In: /usr/lib/systemd/user/pipewire.service.d
└─00-uresourced.conf
/usr/lib/systemd/user/service.d
└─10-timeout-abort.conf
Active: active (running) since Mon 2026-05-25 08:17:58 MSK; 1h 59min ago
Invocation: 1b5d2fb1a18c4305a58f3712586163ce
TriggeredBy: ● pipewire.socket
Main PID: 2492 (pipewire)
Tasks: 3 (limit: 75901)
Memory: 10.5M (peak: 25.9M)
CPU: 24.950s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─2492 /usr/bin/pipewire
nvm,
my laptop speaker unexpectedly started working again, i didn’t do anything to fix it,
sorry false alarm
