Multitouch gestures with Synaptics Touchpad?
So I’ve recently installed Bluefin on my old Thinkpad T420, which is equipped with a synaptics touchpad. Normally I would use a three finger left/right swipe to switch workspaces, but this appears to be non-functional. It didn’t work on Silverblue installed through Universal Blue either. (I’ve never had Silverblue from the default Fedora media installed on it, so I can’t speak to that.)
Now, this machine has previously had openSUSE Aeon installed on it, and it worked there, so I know it’s possible to enable it, but so far, through the websearching, I know that this has likely got something to do with libinput and configuration, but about 95% of what I’ve found applies to X11 sessions. Which isn’t that helpful when you’re using Wayland.
Does anybody have any insight, or are there any logs/configs I can be pulling to try and sort this out?
