Can't detect touchpad
Hello, after an aurora-stable dx installation, i can’t access touchpad settings in KDE system settings. I am using a lenovo laptop. I’ve never had any problems with the touchpad until now. Does anyone have any idea why it might be happening?
sudo libinput list-devices
Device:           MSFT0001:00 2808:0101 Touchpad
Kernel:           /dev/input/event6
Group:            6
Seat:             seat0, default
Capabilities:     pointer gesture
Tap-to-click:     disabled
Tap-and-drag:     enabled
Tap drag lock:    disabled
Left-handed:      disabled
Nat.scrolling:    disabled
Middle emulation: disabled
Calibration:      n/a
Scroll methods:   *two-finger edge
Click methods:    *button-areas clickfinger
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Accel profiles:   flat *adaptive custom
Rotation:         n/a
After a bit of research, this is a kde plasma bug. I managed to solve it with this command: kcmshell6 kcm_touchpad. This only a command to make the menu show up but it’s effect is not permanent.
