Long press (right-click) not working correctly in Nautilus (Bazzite) on an AMD touch device
Recently picked up a Minisforum V3 tablet/laptop and have been trying out both Bluefin and Bazzite. Overall an amazing experience with both. I run Bluefin on my laptop already but was keen to try Bazzite for both gaming and Waydroid features that might me more suited to this touch device.
I tried Bazzite first and the only quirk was how the long press in Nautilus didn’t function as expected. The right-click context menu appears with a long touch but disappears when you try to select something. I assumed this may be an upstream issue but when I rebased to Bluefin, it functions as expected.
I see there is a recent issue opened, https://github.com/ublue-os/bazzite/issues/2015 but this seems to be an issue with right-click in all apps on a Steam Deck. I only have this issue in Nautilus. Has anyone experienced something similar? If so, have you found a way to correct this behaviour?
Appears to be fixed in latest updates! Legends. Something in the mutter update?
Yes:
Huge tip of the hat and thank you. Pleasure to follow along all this awesome development work.
