Libreoffice runs with gtk
Switched from kde workstation to aurora and it is great not haveing to do a thing to set things up. But… I find that libreoffice writer runs with gtk and not with QT like on workstation. On kde workstation it installs from fedora repo’s but now I am using flatpak. Any idea’s on how to iron this problem out
From LibreOffice flatpak site: “The LibreOffice Flatpak is using LibreOffice’s GTK3 backend.”
If you really want LibreOffice with QT, then maybe install it inside distrobox. The simplest way is to use BoxBuddy. I have written instructions for some other program, how to install program in distrobox using BoxBuddy, but it should be obvious how to use LibreOffice instead.
